jacoviii
- Independence Mo
- 255XD
@jacoviii thanks for all the help and pics. I hear you,your logic makes sense to me. I've had this sub in my last two boats and it performs very well in a comparment. It seems Wetsounds recommends different for some reason.
STEALTH AS-10 | Wet Sounds 10" Active Marine Sub Enclosure
Wet Sounds’ marine stereo systems and equipment provide crisp, high-quality audio that’s loud enough to be heard whether you’re fishing a local pond, water skiing on a lake, or tubing on the ocean. Enjoy unparalleled protection from water damage with Wet Sounds’ state-of-the-art equipment.www.wetsounds.com
"The physics of sound tell us that any subwoofer increases its output when allowed to “load” into a wall, corner, or some other structure."
Yes when a sub loads in to a wall / corner in a room and you are in the same room. Cars are the nearly the same but a bit different.
When you put a sub in a box then but the sub-box in a fiberglass box and stand out side of it this is not the same. The output of the "loading" would need to be vented into the listening area. This would make it a 4th order band-pass. In a perfect word the fiberglass box will act as a passive radiator but this takes more math and tuning to be right.
With sub in a compartment you are hearing whatever the harmonic frequency of the fiberglass is not the note the sub is trying to hit.
