2020 AR 210 Battery Wiring
HangOutdoors
Royal Oak, MI
I have ran all the wiring for the tabs, fuse blocks, Garmin, vapor alarm, second bilge and high water alarm. Wanted to drop in original battery and test a few things so I can get on the lake tommorrow and do some more testing.
Anyhow, before i add the second batterry and such I want to test.
I cant find my picture of the Battery hookup when I removed it last fall.
5 wires, three are labeled house, and ground 1 and ground 2, but two are un labeled.
Not sure if the are grounds or hot. Anyone know?
I believe those are the engine grounds, so red to red all the rest black, i think. Found an old thread.
Looks like you have 3 wires labelled as ground... I believe you'll have a ground for each engine, one for the rest of the systems and maybe another for the bilge pump?
Can you trace the positives from the battery switch?
2 are labeled ground and 1 is house. The other two black I am pointing to one each goes to each engine on the back side see blue circles in picture.
Those are ground cables to each engine. Yamaha does a good job of either using red cable or wrapping the loom with red tape to indicate positive.
Yes I concur, engine grounds - don't forget boats are fiberglass so they don't have common grounds like vehicles so everything needs a positive and ground wire.
