OldFireGuy
- Wake
Any thoughts on the AR190 vs the AR195? Such a price difference......is the 195S or AR195 worth the price difference?
Price went up from 2020 - I think the list on our 212s was 56 and change?Just talked to my local dealer..... $59,592 for the 212S on a trailer...they have been allotted 6 boats for early release.
i'm looking for an AR210...said those engines seem to be a delay, would expect them in mid August.
The 195 is 100% worth the $6k upcharge.Any thoughts on the AR190 vs the AR195? Such a price difference......is the 195S or AR195 worth the price difference?
that will be great, increase by 1 foot and $20,000.
I suspect the used market is going to be HUGE this time next year, and there will be many deals to be had.Thats gonna blow my AR240 upgrade plans right out of the water............
Dream on, that's all we can do.
You had me when you started talking sleds!!!Many of the OEM's are trying to standardize on common parts and engines are no different. Sled OEM's will use the same engine, across product lines.
Yamaha was super smart with their latest 999 turbo engine. It's used in their flagship sled in a Turbo and NA version in their SXS. They also OEM it to Arctic Cat/Textron for their flagship sled and SXS. And along side the 1049 triple, they share tons of parts in MFG and service.
Go to a boat dealer and ask them how easy it is to stock parts when they have only two engines to deal with. Let alone squash the rumors if or if not a Yamaha 1.8 is next to bulletproof. They bank their entire line on two engines now, that's a bold statement.
Heck, SeaDoo and their Spark, uses an ACE engine that is shared in the sled line. In the Spark, you pay for the amount of HP you want, and it can be upgraded, or sold to you pre programmed! In the sled, they just give you three modes on the dash for performance or eco mode. And that Rotax engine shares parts and design with other 4-stroke ACE engines in the BRP spyder and CanAm X3 SXS. It's smart business.
So the days of engine choices are limited, and that's fine in my book. As long as the choices that are their are solid and you don't have to think about them. Heck I only open my engine bay once a day to give the engines a breath of fresh air before the first fire up. Other than, it's annual maintenance. That's the reliable car-engine mentality we want as boaters.
Now unlike the Snowmobile world, these boat engines are not tinkered with as much as the sled guys. Since this is a family sport, we value reliability over top performance. (with noted exceptions on here that have done some great things)
Most Yamaha engines in any product line leave a lot of HP left on table that can be tapped easily. We have seen the turbo 999 engine come stock with 208hp, and be spooled up over 350hp on a trail machine. And still be reliable on pump gas. I don't think we will see boat guys doing that, as more HP just shows the limitations of the rest of the very expensive drivetrain (pump/impeller) too quickly. In a sled, you clutch and stud, and you can put 350hp to the ground. On a boat you can't do that so easily. So don't expect anything more than what we have seen already with the SVHO engine in the 275 series and 195 series. But that's fine, that's a nice performance bump if we are close to 500hp total like the 275 claims.
A lot of great points in that post.
I still want to see someone put a water cooled turbo manifold on the side of a 1.8L in a 190, and run an aftermarket ECU setup. Will need a bigger fuel pump, and bigger injectors, but I suspect the block/heads can handle the power adders. Given a large enough water-air intercooler, and I think there is big power to be made there.......Getting the pump hooked up will be the hard part IMO. Several have shown the hull is good into the 60-ish mph range. Imagine picking up a used SX190 for $15k, throwing $5-7k of parts on it, and running 65-70mph with some of the other "go fast" boats that have so much more cash invested.
I'll keep dreaming until I get the spare cash to make it happen![]()
You had me when you started talking sleds!!!![]()
And a jet powered twin engine pontoon!!!Rumor is the 24’ line will increase a foot to 25’ for 2021.........
@adrianp89 ....fingers crossed. Where I live you are lucky to get a Yamaha jet boat at this time of the year and if you can find a color you like......you should play the numbers as your luck is that good lol!I really hope they keep a yellow color for the 21 footers. With any luck I’ll be out of my boat in a month or two. Love the current 212x in yellow but probably be tough luck to get one.
What is the rated HP of the SVHO engine. I am planning on getting the 195 FSHThe big point here is similar in the PWC world. PWC MFG's have had a gentlemen's agreement to stick to the US Coast Guard recommendation of 70mph limit. And they have all done just that within 5pmh. Some MFG's dreamometers will read higher, but on GPS, they all hit 70-73mph since the days of my first GP1200r. (But they get there a hell of alot quicker with 300hp these days)
Top speed will never be a concern for Yamaha. As they know most of their owners are not comfortable with controlling these hulls much over 45 in the most ideal conditions. But having that Hp to push around 2000lbs of ballast without over working the engine is a different story. Thus the reason for 500hp in the 275 to push that monster around. (or a new Yamaha surf boat)
Look at the most expensive Wake/Surf boats putting out 500-650hp, but top out at 35mph in a straight line. They are purpose built machines. And honestly, if a 242x came out with 500hp, but was pumped properly to put that hp to the water with 2000lb of ballast, SIGN ME UP! I could care less if it went past 50mph.
To this day, I have no issues with how quickly my boat will get out of the hole and outrun many boats (only to get passed on the big end) but by that time, I have embarrassed them and I don't need to prove anything more. HA!
So if anything, I could see a pair of SVHO's and as shown in the 195 series, they can make great surf power. I'm am blown away by what guys are doing with the 195, and that's just one engine!
