210 FSH Changing Room Question
Tailwaters
St Joseph MI
So just wondering if the 210 FSH has the same issues with water finding its way into the changing room or did Yamaha change the design of the liner to redirect the water to the bilge area?
Knock on wood, I have not had any water in the head/changing room as of yet. We have had quite a bit of splash and dripping water from "the crew" and have maintained a dry head/changing room. I have about 50hrs on the boat now.
No problems here...
Not a drop. I did seal the anchor locker drain w/5200 before I ever even got the hull wet, but even with quite a bit of water in the floor locker, people in and out of the boat, etc, the only real water in there is when I hose it out after cleaning. The curtain zipper on the other hand...
I have. 2019 210 FSH. No water in mine either
Had my new FSH 210 for a couple weeks and no water problems in the head/ changing area,,, bone dry.
@Tailwaters I have about 60hrs on mine and never had a water issue. The head has always been dry even after the passengers get back in the boat dripping water. It finds it's way out of the deck drain as it should.
