215 dual battery
Winerocks
Bloomington, Indiana
HO Impulse
Hey Scarab people,
I’m looking to install a second battery in my 215 Impulse. I’ve read the threads on single engine installs, but can’t find anything for twin engines. I have the wiring part figured out, but not placement. I’m prepared to fabricate whatever I need to for the install. I’d prefer to keep it in the engine bay if possible.
any ideas or experience?
Thanks!
jetboy
255 Open ID
Hi Winerocks! Can you post a couple of pictures of your engine bay? In my 195 I used the open area on the starboard side (opposite the main battery) screwed in a tray and mounted there- routing the cables around the back to the dual battery switch. I plan to do the same with my 255, but am just in search of a smaller deep cycle battery.
Let us see some pics and Im sure ideas will come flying!
Winerocks
HO Impulse
I’ll post some pics either tomorrow or Friday. I’ve heard of people putting a second battery in the starboard side storage locker under the bench seat. I’d rather not eat up storage space if I can help it. It is by far the easiest solution...
Winerocks
HO Impulse
I got on the boat today and took some pics of the engine bay. The last pic is the storage compartment on the starboard side.
A750E3DC-A49E-41A7-BFC5-3853694BF90A.jpeg0F6D9ADA-DE31-4512-B235-D0DE9DDBE141.jpeg87DA6EAA-938A-4EEC-A764-7331FFDBDA2B.jpegC670544D-FDE3-4248-9C14-108B698D0600.jpeg4C953002-ECEA-4A6C-B1C5-4EF389712C7E.jpeg5C7A44BE-5FFE-4034-9293-C49DD7F6EE9C.jpeg
Dean P
Florida
Chaparral
VRX
I don't have your boat but could you turn your existing battery 90° and place another along side it?
Winerocks
HO Impulse
I considered that, but the battery switch and fuse box are there. I may be able to put one behind or “aft” as boat folks say, but would have to build and glass in a platform. Possibly a smaller battery. I’ll come up with a solution, I just need to pop open the back and pop a few beers.
4x15mph
Downingtown, PA
Are you going to install an onboard charger and if so, don’t you want the 2 batteries in the same area?
Dean P
Florida
Chaparral
VRX
This is a good point. My batteries are on opposite sides. With my charger I had to modify the cable to add length to reach. Not a big deal and the charger works fine.
Winerocks
HO Impulse
I’ve got a dual charger, but the cables are pretty long. I’d prefer if the batteries are close together though.
jetboy
255 Open ID
Its hard to tell, but on the starboard side between the fuse cluster and 4" blower tubes, can you move anything around and get a 10" x 7" in there? or the space further aft behind the first battery?
Winerocks
HO Impulse
Jetboy, Starboard side makes the most sense for weight distribution as well. Ductwork is not my specialty, but how hard can it be?
