jpass
- Orlando
- SeaDoo
- Challenger
Another thing to check is the pulley alignment. You mentioned that it was a little offset from the other pulleys. Can you place a straightedge to check in two dimensions?
This is more than likely the culprit. Does the OP noticed black dust all over the place? That's usually a sign of the belt wearing abnormally. Using a straight edge to check alignment is the right idea. If the bearings are going, that could also put excessive drag on the system and allow for the pulley to wear rapidly. Over tightening the belt can also lead to premature failure.
Daxxer: can you post some pics of the shredded belts and the current alignment? Pics would be very helpful here.
![Flag [flag] [flag]](/flag.gif)
