Redwhiteandblue
I ordered two 1.8 kits from jet boat pilotWhich kit / filter did you end up using? I'm about to order for my 10 hour on my 2021 252 as well!
That's what I was hoping to hear. I've read nothing but 4 qts (kit) and people extracting anywhere from 3-3.75 qt. I knew some was left in the motor dye to the nature of the process. Just wasn't expecting over 20% retention of old oil. Thank youYou won't be draining all of the oil unless your doing a complete change, you'll be sucking a majority out of it. According to the literature you'll be using 3.91qts with a filter change.
Check this link out for the basics on an oil change
https://jetboaters.net/faq/#faq-18
This is my plan also, followed by checking to verify.I like to add what I took out. So far I have only been able to extract 3.6 qts or so if i recall correctly the last time I did it to my Waverunner(same exact engine). I keep my jugs from previous oil changes and measure how much I have taken out and replace the same amount. Keeps me from overfilling it.
As @Babin Farms mentioned you will never get out all the oil using the normal methods so the 5.6 qt's is for a totally dry engine.
Agree 100%. Always good to cross check. I check oil each trip to monitor.Adding what you take out is not truly optimal, imho by itself. You should check the oil level after warming to determine if you have low, good or too much oil, first. Then using that as a base line, add oil back in, then check warm again and bring up to the optimal level, which has been determined is just less than half way for performance. Of course you should level the engines as much as possible, in water is best place to check. Oil levels can grow with possible water intrusion or it can foam up a bit. Overtime if you keep replacing what you took out it could be too much.
Same motors!I changed my 212x last weekend. I got over 3.5 quarts out before removing the filter on each. Looked closer to 4 than 3.5
I put back very close to 4 quarts in each with a new filter.
The 212x has two NOT supercharged 1.8 engines. Not sure what yours has.
Actually for the 1.8L engines you want the boat/engines to be level, not the trailer, with the engines off. For my boat, I found the trailer tongue is slightly low to get the engines "perfectly level". I have a 10 inch level I use to verify the engines are level before I pump out and refill.If you change the oil while it's on the trailer, make sure the tongue is level as an uneven trailer will throw your readings off. You can also lower the tongue to get some extra oil out of it if you're vacuuming it out.
