kaylix
- NY, NC, GA
- Sugar Sand
- Tango Xtreme
OK, I'll try to do this in an organized order:
- Boat on land, with water hose attached. Cranks no problem
- Boat in water, starts and drive for 30 minutes to destination. Turn off everything but, battery is in on position. After about 40 minutes boat will not crank and battery is dead. Tow of shame to marina.
- Take boat for repair. Carbs gummed and a small fuel leak and batteries should be replaced.
- Carbs are cleaned and leak repaired by marine mechanic.
- Put boat in water, won't start. Batteries dies.
- Buy new 625CCA starting batteries.
- Next day boat cranks (1 or 2 squeezes of fuel primer bulb) and go to marina for fuel. Fill tank. Won't crank. Batteries die.
- Return new 625CCA batteries.
- Purchase 1000MCA Staring Battery and 685 Deep Cycle Battery (1 for starting and switch to other for running)
- Boat still in water with new batteries. Squeeze fuel bulb 3 times. Won't crank.
- Put boat in neutral and move throttle to 1/4... won't crank. Kind of a strong smell of fuel.
- Check new Batteries with new charger/tester. New batteries are at about 45% - Charge Each One.
- Cranking but no running.
