rsg1963
- Dublin, Ca.
Thanks captras.Nice job on the Seadek....and I like your charger install. I have portables....one for each battery....not nearly as clean as yours but does the job!
Hey, it works.....and a great looking install. Not sure how effective the solar panels are on mine, but I have been out most of the day with the stereo on and not had a problem, so I guess they are doing their job.Thanks captras.
I also had a portable charger last year but with this stereo pulling so much juice during the day, I wanted something where I could get near-to-shore and simply run a extension cord out to the boat and plug it in. Last year I had to get into the boat each time, lift the seat, hook up the charger, run the cord, then set the charger to the setting it needed to be in. Then, guessing it was ready, switch over to the other bank. This setup is plug and charge for both banks and sends extra current to the bank that needs more juice. Lazy solution? You bet!
Solar panels are an awesome add Yamaha made to your model. I think I may have to get a couple 50w squares, an charge controller and some clever way of temporarily securing them to my Bimini. THEN I'll be done modding this boat.....ahem.....Hey, it works.....and a great looking install. Not sure how effective the solar panels are on mine, but I have been out most of the day with the stereo on and not had a problem, so I guess they are doing their job.
View media item 4431Sorry about that. It's inside the Port-Side swim platform backrest hatch. Not sure what else to call that!@rsg1963 where do you have the plug located? Tough to see in the pic.
Thanks for the help. Going to order one today.View media item 4431Sorry about that. It's inside the Port-Side swim platform backrest hatch. Not sure what else to call that!
Nice! Fun project actually and simplifies one of the most critical maintenance items.Thanks for the help. Going to order one today.
NOCO's are excellent units. Only draw back is having to set the type once plugged-in. At least with my smaller 7.5 amp units you do. The Seadeck covered very well with the exception of the Port-Side bucket seat floor. Where the feet will go, towards the day head, the factory carpet snaps were drilled a little high. I made several compromises in placement. One was there at the foot-well area, another was the seat post surrounds. I'd of liked the hole for the seat post to have been perfectly centered, but I slightly off-set the placement for a more uniform look down the middle. But all in all, it's very well designed. Just a tad more product in a few minor areas would have made the install absolutely perfect. Ultimately, a good caulking job beforehand, can make the holes nearly invisible (unless you are right next to them on floor level).I installed a NOCO Genius and ran the plug in the same area. I will get some pics tomorrow. I have to install my seadek also. Did you have any holes that the seadek didn't cover?
what brand port plug is that? - thanksAdded a on-board dual bank charger so I can now just plug my boat into an extension cord and forget about the batteries. And then added Seadek. Love 'em both. Can't WAIT for Spring. Winter has been good to California, lakes are full!!!View attachment 51070 View attachment 51071 View attachment 51072 View attachment 51073
Here you go.what brand port plug is that? - thanks
Actually, that's the area in front of the storage. Or, another way of saying it, behind the port side chair, not the outer hull.How did you mount on that wall? Isn't it the outer hull there?
