Yesterday I made my 1st voyage with the AR230, how excited I was! .. In general, all went well. Here are my findings on it :
1- I have noticed that the boat has very low power on any RPM less than 6000 rpm, so if I was at 5000 rpm, I would feel the boat is pulling a heavy load!, but once I pass the 6000 rpm it picks up speed fast, is that normal for this type/size of a jet boat? .. I never been on a jet boat larger than my 17 ft Seadoo Speedster, so I can't really judge.
2- The low speed maneuverability is horrible!, I had to move back and forth 5 or 6 times before I was able to slide it on the trailer! .. so would the thrust victors fis fix this problem?
3- The controls were giving a really hard time keeping them on position!, I had to keep them steady with my right hand the whole time cruising!, is I believe there is a way to tighten them up, right?
4- when I brought the boat up the ramp, there was about a 2 gallons of water came off the drain, although when I was on the water, I tried to check the engine compartment ever few minutes with no signs of water, it seems all the water was collected in the rear bilge area.
5- I have noticed there was some water inside the clean out plugs wells.
6- after about 1 hour of 25 mph cruising, I can safely tough the exhausts and the engine block, so they were nice and cool, but when they are idling, I can only see some dripping of small amount of water coming from the side ports, is that normal? .. I forgot to check on them while on high rpm, stupid me!
These were my notes so far, so it would be great to hear what do you guys think?
Thanks a million guys for all the help and guidance that I got from this great forum community, without it, I could never bring that boat back to water.
Finally, here is a small video clip to watch :
