Speedling
- Cedar Lake, IN
- SS
My wife really wants to return to Bimini. I mean, who wouldn't?
So I realized on the trip that trim tabs and sound deadening would be a huge benefit for our boat. My sound deadening made a small difference but not enough.
Started looking into the tabs and got ahold of Lectrotab.
I like the look of the systems and was told of a new controller the SLC.
Broke it down for people can get info on everything!
Here's how it all goes down...
This is the regular rocker control. For my setup, I am quoted 513.60 total. This is the SAF-SC and the size tabs and actuaters I need.
This is the MLC-1 The buttons seems straight forward like the regular rocker however it works slightly different. From Russ:
"The MLC-1 has an auto retract mode for the tabs when you turn off the ignition key. It can also remember it’s last setting and will automatically adjust the tabs back to where they were before stopping the boat.
The MLC-1, also reacts a little different in the way it moves the tabs. End result is the same, but it may catch you a little off guard, if you are accustom to a rocker switch.
For example, if you push “starboard side down” the MLC-1 will actually retract the starboard tab. Once fully retracted, it will deploy the port tab until the starboards side reaches the level you want. (The opposite for the port side)
A standard rocker switch will deploy the port side tab if “starboard side down” is desired. If this isn’t enough, they you manually retract the starboard tab."
This is the new SLC-11 It works like a regular rocker as far as deployment but does the auto retract with key off etc. IT doesn't retract one side when the other side is deployed. I personally like that idea so I can keep both sides deployed without one retracting to add to the other.
The MLC and SLC were quoted both for me at 672.60
This is the ALC which once calibrated should keep you leveled out automatically. I didn't get this quoted as I don't think I would like something so automatic.
My wife says if I buy tabs for Bimini, I better go! That's the deal!
I am torn between the basic manual and the SLC controllers.
For $160 extra is it worth it?
Links for your reference.
Also found:
9 x 12 Lenco Standard Boat Trim Tab Kit #15001-101 which has $391 for kit and $259 for switch but standard not short actuators and wouldn't have the ends turned like my other quotes.
Controls - Products | Lectrotab Electromechanical Trim Tab Systems
Lectrotab designs and manufactures premium quality electromechanical trim tab systems for the leisure and commercial marine markets. The Lectrotab system is easy to install on new boats or to replace existing trim tabs. All Lectrotab actuators are covered by a worldwide lifetime warranty.
www.lectrotab.com
