Alex Renaud
- West Monroe, LA
- SX192
Looking for ideas on what’s going on with my boat, I’m stumped.
A little background. I have a 2014 SX192 that I purchased used last year. The boat only had around 14 hours on it and I bought it from the shop that was servicing it. Currently the boat has around 55 hours.
The first half of the summer the boat ran perfectly, turn the key and go. Around the middle of the summer I had something peculiar happen. We launched the boat and idled out away from the ramp as we always do. Once ready I pushed the throttle down. The boat reached about 6k rpm and only about 10 to 15 mph. Not sure what was going on I pulled back to neutral position and tried again. Worked perfectly the second time reaching full rpm and full speed. Didn’t think anything else about it and it ran great the rest of the day.
The next day we had the exact same issue except this time I had to pull back to neutral a couple times before it would run correctly. By the end of the summer the issue had progressively gotten worse. Each time taking longer than the last. Once it was running fine for the day it seemed to run fine the rest of the day with starting and stopping throughout a trip. The last time we had the boat out last year it took almost an hour of idling around before it would run correctly.
I recently had the boat serviced hoping maybe I had a fouled plug or the shop would find something obvious. I was able to get it on the river last week with my fingers crossed only to see it’s still doing it.
What’s throwing me for a loop is that it’s not a problem that comes and goes. Once it started last year it’s happened every time sense and progressively worse than the last time. Any suggestions are welcome, PLEASE HELP, summer if right around the corner.
Items I’ve already looked at:
Wear Ring appears to be in great shape
New plugs
Throttle cable looks to be adjusted correctly
Cooling ports appear to be flowing properly
The inspection port locks in position fully
Thanks,
Alex
New plugs
Thanks,
Alex
