Accessories fuse location?
Weeb
Denver NC 28037
2017 AR240. I can’t find the fuse for the 12 volt accessories plug on the dash. The owners manual says by the dvsr but I have nothing there. I just had my trim tabs installed and the guy tapped into this for the trim tabs at the helm after I told him to run 12 awg from the battery. I need to know what the fuse size is for this supply and where it is so I can check it. It looks like it’s 14 awg but I’m not sure I don’t see anything written on it. Russ at lectrotab was a little weary about this under a load.
Not sure on your boat but the older boats are on the rear bulkhead in the battery compartment. Mine is right near the battery switch.
I’ve been all through the battery area I don’t see anything. I found a red one under the helm but it runs into the radio wiring plug.
This model is suppose to have two single fuse holders according to the manual. I have a block type that is suppose to be on the E models. Fuses are labeled Main and Audio with a horn and radio relay in there as well. Can I assume the main fuse is for the accessories?
Edit: Its not the Main it is the Audio fuse that the accessories plug is tied into. So does that mean I’ll over load it with the factory amp and trim tabs?
