CrankyGypsy
- Tampa, FL 33615
- SeaDoo
- Challenger
re-wiring the boat with a Blue Sea Dual Circuit Plus (both batteries on, but kept separate - no more flipping back and forth) and SI-ACR. i think i have the wiring figured out for Starter Isolation to the ACR so both ignitions will signal the ACR individually (but each signal won't "spill over" to the other ignition and relay). just want someone to confirm for me which wire to tap to the Diode Bridge: i'm thinking the Brown wire coming from the ignition...
7: Ignition Switch/Start Switch
N/A: Starter Relay/Solenoid is in upper-right corner
