Shookie
- Cary, NC
- 242 Limited S E-Series
I installed a new Fusion head unit on my swim deck today because the volume knob broke off of my old one. Been reading some other threads and got me thinking about some upgrades to my sound system. Everything right now is stock. 6 Polk DB652 speakers in the boat plus JL 770's and the tweeters in the tower. So added up that's 8 speakers plus the tweeters.
Currently Zone 1 (front) is the bow speakers and the tweeters. Zone 2 (back) is everything else (tower JL's, rear cockpit and swim deck.
My main goal is more volume for the driver (me). I end up cranking the system up nearly all the way and people up front and in the rear seats complain the volume its too high. I'm not looking for my boat to be the party barge with 10,000 watts blasting for all to hear. From what I've read (and it makes sense), it sounds like adding 2 speakers in the middle of the boat is what I need.
So, if I add 2 speakers that puts me up to 10 speakers plus tweeters being driven by the Fusion. It's rated 4 x 50W (@ 4 Ohms). My overall volume will drop and that assumes I can add 2 more to that head. Adding a new amp makes a ton of sense to increase the overall volume level without having to turn the volume up all the way which brings distortion and shit sound quality.... I can get 2 more of the Polk for $89 which is appealing. I can't see much of a reason to get anything different.
A subwoofer is intriguing. Someone posted a cheap JL for like $110 which sounds like a ridiculous low price. I just don't know that I want to lose space where it would go.
For an amp, not sure how many channels I want to run. I'm also not sure how the tweeters factor into this. The Polk's are rate 100W continuous and the JL's are 70W continuous at 4 ohms. If I went with a 5 channel amp, that means I'm running at 2 ohms right? Not sure what the tweeters would do. I could disconnect those (although I read someone mention that they sound better with the mid speakers installed). If I went with a 4 channel amp, am I pushing 1 ohm then? The Fusion unit is pushing all of these now minus the added pair of speakers I will add. The JL MX500 perhaps?
First post.... looking to get ideas/recommendations and for others to validate my thinking.... I haven't even thought about the exact locations and wiring yet. Have a few more threads to read to get ideas. I'll do this all on my own to keep the costs down so need help from this forum. Thanks!
