Adding hinged seats to LS2000
4x15mph
Downingtown, PA
Anyone add hinges and latch to their LS2000, front seat cushions similar to how the LX210 is set up?
I ordered the latches which are on sale at West Marine along with some hinges. I have to think this will be an easy mod and will provide additional storage under both seats.
Has anyone done this? Thoughts?
Here are the latches I ordered and a pic of the LX210 set up
https://www.westmarine.com/buy/southco-marine--mt-sundecker-panel-latch--15183015?cm_mmc=PS-_-Google-_-GSC%20-%20Product%20Type-_-15183015&product_id=15183015&adpos=1o7&creative=108421551484&device=c&matchtype=&network=g&gclid=CjwKEAjw16HLBRDF9L2UmOCH7U8SJAASVESoCFmigjhv3Kkvkb9w30IfHJkPudMuNog_ysR3Un6HoxoCwFHw_wcBScreen Shot 2018-10-11 at 9.34.13 AM.png
treeskier
Ocean City, MD
great idea i look forward to your finished product
dabomb6608
Marion, IL
LS
Hey 4x,
Did you ever make any moves on this project? I've been trying to find pictures from a LX210 boat showing this area with the seat up. Does the storage just go down into the hull similar to underneath the helm storage bins? Looking at the parts diagrams and your picture of the underside of one of the seats it looks like it wouldn't be a tough job. Once you get past the lump in your throat from cutting two big holes in your boat that is...
4x15mph
Downingtown, PA
I ordered the parts over the winter and will be installing now that the weather is getting nicer. I think the holes are already there and our seats just sit on top. I did add a door on the side of the dash console area which has added a lot of additional storage for garbage, towels, etc. I'll let you know once I tackle this but I just did an engine rebuild along with rebuilt carbs so I have some breaking in to do first. Hope it is a good summer
dabomb6608
Marion, IL
LS
I hear you on the engine rebuild and breaking in. As I mentioned in my thread I'm still working on getting all of the bugs out of mine mechanically before I start doing the upgrading I want to do.
Are the bow seats mounted with screws from underneath? How do you access them, I guess just from getting inside the hull at the consoles?
Please post up some photos of that door you added if you get a chance. As well as the seats once you get there.
4x15mph
Downingtown, PA
dabomb6608
Marion, IL
LS
Interesting. Seems that item title is way off or I am completely missing something lol. Do you have any pictures of the finished install itself? I have contemplated putting some carpet like seen in the newer yamaha boats down in the dash compartments. Then maybe building up a removable flat surface to give it a "bottom" instead of just a void into the abyss of the hull.
treeskier
Ocean City, MD
I would advise against putting anything in the bottom under the dash compartments. A few years back I found some containers (yes I put drain holes in them) that fit down there perfectly and thought it would be a great spot to store items you didn't need frequently (extra life jackets, extra ropes etc.). Apparently it stays pretty moist down there and everything heavily mildewed. Threw out everything I stored down there.
dabomb6608
Marion, IL
LS
Good to know. That does sound about right as there seems to always be a bit of water in the lower bilge (back area specifically). Maybe for the people that store these indoors that wouldn't have as much of a issue. Mine sits outside about 100% of the time and currently is uncovered considering I am working on it semi frequently and haven't washed it yet since buying it in March. Once I actually give it a proper cleaning I will start throwing the bow snap on cover and full cover that came with it on after each use.
4x15mph
Downingtown, PA
@dabomb6608 , yes I noticed that the title is incorrect and that is an amazon problem right now. Weird
I do not keep anything stored overnight in any compartments on my boat. I like the door that I installed and we use that for a garbage can. When/if I do the seat hinge, I'll put a container there and we will store towels there which will be easy for everyone to get to.
dabomb6608
Marion, IL
LS
I would imagine as long as you get a tight fitting compartment to fit along the lip of that seat cutout and a weatherstrip seal on the edge that it would have less issues with mildew. It would be sealed off from the moist atmosphere of the bilge at least.
4x15mph
Downingtown, PA
I would still recommend pulling out everything from the boat. I have been through a few boat covers and the mildew that develops has always been because of left over vests, skis, beer cans, etc.
the MfM
I took one of the seats off for another project and to clean underneath the seat.
On mine they used pt plywood instead of starboard. The fiberglass is not cut out. You can see in the pic they use two studs to hold it in place. The front one was a pain to get off. You have to reach through the cup holder.
STill seems a worthwhile project given the amount of space available. But the bottom of the seats will need to be finished off (probably with a perforated vinyl so it doesn’t mildew.) And will have to figure out some sort of gasket for the fiberglass rough edge after it’s cut out.
I might try a HD Velcro instead of the southco latches.
4x15mph
Downingtown, PA
@the MfM , great shot of the seat. You are saying that underneath the seat is solid fiberglass so we would have to cut it out? In the picture that I saw with the laco latches, the underside of the seat was a plastic and not plywood.
How did you get your seat off? Its just 2 nuts? one that you could reach from under the console and the other you reached through the cup holder? How will you get the cupholder one back on without dropping the nut or are you now committed to using Velcro?
I trailer a lot so I would be concerned about Velcro or anything else that isn't completely bolted down
the MfM
Yes, under the seat cushion is solid fiberglass.
It was held on with just two nuts. I got the front one off through the cup holder. I don’t see an easy way to get it back on.
I’m planning to put it back on with hinges. And figured I’d try velcro to keep it from bouncing open (instead of the latches). I might as well go ahead and cut out the opening for storage now that I’ve got it apart.
dabomb6608
Marion, IL
LS
For your rough edge, try and source some weatherstripping similar to this 120" Car Door Seal Strip Rubber Weatherstrip Protector Edge Trim Guard Pinchweld | eBay
That will protect the sharp edge and you can even apply some adhesive to better secure if its a loose fit. Do you have any pictures showing the area with seat removed?
the MfM
the MfM
20 years of grime under the seat...got it cut out. Fiberglass is 3/16” thick.
the MfM
Got the seat hinge on and in place temporarily ..the only SS hinge Lowe’s had was a piano hinge. It works but was a pain to get the screws in with it in place. Need to pick up some machine screws and nylock nuts for the fiberglass.
Two minor issues. The seat needs to be slid back all the way towards the stern so it will open without binding because of the angles. So there is a slightly uneven gap around the seat/fiberglass. Most people probably wouldn’t notice.
The other issue is the LS boats have an extra bolster at the front edge. That bolster bumps into the grab handles so the seat won’t open all the way.
I’m also going to order the latches. Without them the seat could flip up if someone stands on the edge of it.
the MfM
Overall, nice cheap mod that gains a little space. Nice spot for some extra lines or the fenders. And now I have nice easy access to the front of my anchor winch.
