Adding sxm?
2019scott195wake300
Scarab
195 ID
ok guys adding xm to the boat. Just wanted to see if the antenna needs to be on the out side of the boat or will it work on the inside? If it needs to be on the outside where did you guys mount it?
sunbyrned
Louisville, KY
Mine is mounted under the helm. Screwed right into the fiberglass. I can send a pic in the morning if you like.
The xm radio antennae is a line of sight device. It can still pick up a signal if it’s installed in the helm but it won’t be a strong signal. One way to check it is to leave it loose and exposed before installing it and simply sit on it / cover it, doing so will cause signal loss almost instantly. Uncover it and the signal resumes.
sunbyrned
Louisville, KY
I might have spoke too soon. The box he is displaying is mounted under my helm but I believe the hockey puck GPS system is at play as well.
The hockey puck is the antennae for the gps speedo.
my 2010 242ls came with the xm module installed, the antennae was mounted under the helm/head unit. I first moved it on top of the hockey puck but lost signal whenever someone sat on it . I have since moved it to the top of the tower and have had no issues with signal loss since.
Hmmm. Pics please...
Here are a few screenshots of pics from previous posts. It was fun looking for them.
The black box in the upper left corner is the oem xm module, the antennae is Out of sight but is behind the fiberglass wall at the front of the pic.
the white cable leads to the hockey puck and the gauge cluster.
2019scott195wake300
Scarab
195 ID
thanks guys im going to see what i can come up with. just wanted to make sure it needed to be mounted on the out side of the boat. i just hate putting holes in a new boat!
@2019scott195wake300 , Only the end of the antennae needs to be out in the open, the other end is about the thickness of a bid pen so if you have to drill a hole it’s not a big one and there is a good chance you can lead it though a prexisting opening where parts like the dash and windshield connect. By the way I have the same module as you do installed with with my fusion head unit. Good luck.
sunbyrned
Louisville, KY
Well, I learned something new about mine by investigating this. I never really followed the antenna wire. Just assumed it was wired to the hockey puck. I followed it though for this thread. Turns out the antenna is sitting under the helm, on the ledge of the fiberglass. I took some pics. Follow the thin black wire. Hopefully you can see it. I also took one of the box he needs to mount. I also took one from the top view to give you an idea where it’s laying underneath. I get great reception.
