Adhesive help
Wesley Cobb
I have a piece of foam loose in the engine compartment. I want to stick it back to the hull where it belongs. Everything I have used up to this point has not worked...it either soaks into the foam or doesn't adhere to the uneven fiberglass hull surface. Any advice on what to use?
weaselman
Waterford, CT
I have used 3M High Strength 90 adhesive glue with no issues. I hold the foam in place for a few minutes and it holds.
Wesley Cobb
Awesome! I will get some and give it a go.
