Adjusting bucket from dash settings
Ralph195
North Miami Florida
195 G
Good morning fellow Rotax owners I have a 195 scarab 2016 And someone told me that I could adjust the bucket through the settings in the dashboard is this true?
If so does anyone know how to do it.
Right now in neutral the boat creeps in reverse about half to one mile per hour.
All appreciate any input on this.
Thanks
I have this option on my Medallion II screen. This is not standard on all Rotax products. While boat is running, you're in neutral and you're on the screen showing your RPMs, you'll have an arrow up above the "N" symbol and an arrow below. If you do not see this you do not have this feature.
To adjust that manually, there is a brass nut you can turn CW or CCW (which the cable runs thru - along side of the jet) to adjust it. Remove cotter pin, pop of plastic cover and lift the brass nut from bracket. In your case you'd turn it CCW to shorten the cable (from the nut to the bucket). Make sense?
