camoto
- Plymouth, MA
2014 AR192:
I've read the other threads about "throttle drop" and this doesn't appear to be my problem. When I put the throttle in the 2nd position (TDE, still idling), it often slips back on it's own to the first position. I've increased the tension and it makes the throttle stiffer, but only past the TDE position in forward and reverse, everything in between is still really loose.
Is there another adjustment I need to make to keep the throttle from pulling back out of TDE?
Thanks in advance for any help!
