Dnickers9
- X
2018 212x 34 hrs.
This weekend went to start boat before going into water, the starboard (right) engine would just crank and not start. Opened the lid and it cranked over and started. While running both engines I would close the engine lid with regular pressure it would immediately kill the starboard engine and would not restart (just cranks) until I lifted the lid. I checked all the connections to the engine, fuel rail and injectors and didn’t find any loose connections. I also smacked with my hand, while engine was running, all these components with no issues. When you gently and slowly close the lid the engine stays running and will restart once shut off.
The engine cover has some dips that come down and are covered with a black foam egg crate. This bulge if it were deep enough would land directly of the fuel rail and injectors. That is the only thing that I can see being an issue, but I do not think it comes down enough to physically touch the engine since the foam looks to be unstitched. All other moving parts have plenty of clearance.
Any ideas?
Any ideas?
