Thank you very much.Works like a dream at any speed or depth. Hoping it works out, but this is how the dealership mounts them
I think I got it right. My concern is with riding on top, quite literally in this case, of the cable (criss-crossing the ride plate) and the transducer assembly. My concern may turn out to be completely misguided, and I hope it is!
Please keep us posted how this holds up over time, if it works and holds up - it could be a great install.
Okay, thanks. That's good to know. The 23 mph wake looks fairly small and similar to what I've got now. The Nautique I have now has a bit of a bump at 30 mph, so as long as this boat is anywhere close, that's good enough for the wife. I'm leaning more towards selling mine and getting the AR190. The extra room and less maintenance with salt water are HUGE plusses. Even with thorough flushings, salt water has been a very costly menace on my inboard.Yea same as above. Especially with no ballast or anything and a regular load of ppl and gear at 30 the wake is non existent. Very manageable for skiing. Should feel quite roomier than your 17.5 foot boat now as well.
That's my setup since I got my boat for 1 year now. I bolted it down inline with the keel/rudder.
No impact to the boat's performance. No rooster tail. Best of all, no drilling into boat hull and the wire is routed up through the wet compartment drain so no worries about wire dragging in the water.
Transducer is always under water with clearance on both sides so side-imaging isn't compromised and depth reading working at higher speeds (~25mph+, depending on water condition and depth).
Transducer is protected when beaching boat stern first.
Unfortunately I don't since it's sealed underneath the wet compartment. I pretty much routed the cable through the wet storage drain hose. I had to cut the hose and fit a Y-Splitter tube to allow the cable to escape from the hose to the head unit. Silicone where the cable leaves the Y-tube so water from the wet storage drain does not go into your bilge.Do you have any pics of how you ran the wire? Looking to do mine like yours.
Where did you get the transducer mount that you used? Getting things ready for install.View attachment 87569
I got it from Amazon. $13.50 when I bought mine.Where did you get the transducer mount that you used? Getting things ready for install.
Looks like the cable is just ziptied to the long bolts that mount the venturi nozzle and wear ring to the transom plate.Is there going to be a problem if you ever have to work on the jet nozzle or pump? Will you be able to get the nozzle/pump out of the boat without interfering with the wiring of the transducer?
