84rzv500r
- Lower Keys MM29
I have a horod too...it's my boat...attracts ho's from all over...i have seen a thread on bikes and boats and guns and guitars, howabout horods?
Not quite a Hot Rod, but it goes fast and handles like it is on rails....
This is my full tube frame CRX built for SCCA GT5/GT4/GT3/GTL. 1.6L DOHC engine (turbo or non turbo depending on the class), 5 speed straight cut dog box with interchangeable gears, 9.5" wide Goodyear slicks, custom dual a-arm front suspension, custom Mumford Link dual trailing arm rear suspension. Dry Weight about 1,500 lbs and the NA motor puts out about 235 HP to the ground.
boats and Ho's some have HO already on the Side!I have a horod too...it's my boat...attracts ho's from all over...
AWD/manual?Does this count? CT4 BlackWing
German Hot Rod
I am aiming for a 992.2. That will be my hotrod lol.
I inquired at the Porsche dealer about a new 992 manual. They said if I ordered then I could expect it in about 2 years. No thanks to that.
Times are coming down quite a bit. ADM is disappearing too. It’s also strongly model dependent…. Want a GT3 good luck.
VW says no newly designed cars released after this year will have manuals. They are disappearing from BMW’s as well.Yeah I think the ma ual is only available with the Carrera S, and so that wasn't helping matter.
