AR192 Ford Oil Filter
skbishop90
Alabaster, AL
AR192
Anyone know the Ford Oil filter number for a 15' AR192?
skrip345
Sedalia, MO
I don't, and maybe I should leave it at that. BUT. Especially while under warranty, I would not run anything but the recommended Yamaha filter. IF you had a failure, and there is an aftermarket filter, BOOM warranty claim denied. For the possibility of a few dollars saved, I would stick Yamaha. Maybe I'm just a sheep though! Somebody probably knows and will chime in. Happy boating!
SamCF
Greenville, SC
SX192
Myself and several others use the Motorcraft Fl-910s. I will be using the FL-400s next oil change. It is a longer version of the 910.
If you use something other than the factory filter, do your own research and make sure it will work for you. There are a lot of opinions here, and using the factory filter is probably the most common.
skbishop90
Alabaster, AL
AR192
I normally order a oil change kit from Jet Boat Pilot but I ordered it on Monday and haven't even gotten an order confirmation yet. They called and said it would be shipped from a third party distributor but they "felt confident that it would only be a day". So I got sold. Id Like to change the oil this weekend and have it out on the water!
skbishop90
Alabaster, AL
AR192
Anyone know the Yamaha Part # to order off Amazon or somewhere else?
DBamaC
Hoover, Al
AR192
I think I have a spare one if you want to take it and give me one back when you get it.
Cobra Jet Steering LLC
Vendor
Florida
I use motorcraft FL-910s filters on my 1800 engines and have for many years and thousands of hours, never had a warranty issue even when they replaced my engine for a failed timing chain, a couple years ago so do what makes you happy , federal laws cover warrantees
