xedelatorre
- Montreal
Has anybody stored an ar192 in a 20ft deep garage? If so, would greatly appreciate some tips
19.4 bow to stern.... no problemHas anybody stored an ar192 in a 20ft deep garage? If so, would greatly appreciate some tips
Thanks a lot, I was more concerned about the depth than the height! There's not much you can do about depth but about height there are options as per the video, thanks for sharing, I'm still holding my breath until I see it inside with the garage door closed ... Mine is a 2015 so I'm not sure the fix on the video will be the same as for the tower, on the 2015 it folds backwards.@haknslash has a great write up on getting the tower down and stowed away for a garage opening under 7 ft. https://jetboaters.net/threads/how-to-get-your-2016-ar192-or-ar195-in-a-garage-less-than-7.10369/ and a video on youtube, the guy is great for detail and help!
Door height is standard at 7 ft, will have to do some tricks to lower it a few inches ... have seen some like putting the trailer on dollies and the front on a floor jackJust be sure your door height is high enough. It seems that's where most people have problems.
Thanks so much for the pictures, I'm very much relieved to see your pictures! The height will be the next challenge, door is 7 ft and I measured a similar 2015 ar192 at the dealership with the tower collapsed at 7 ft 4 in give or take an inch, this will be the next challenge, wish me luck and if any tricks on lowering the height of the boat please pass along, will greatly appreciate thisIt will fit fine in a 20' deep garage. Mine is at 19'2" from rear of the swim platform with the trailer tongue folded. The tip of my bow is at the same point/plane where the tongue folds.
Forgot to ask, in the video I cannot tell if the trailer is sitting on dollies and the tongue's position, is it at its lowest or there was no need?Height won't be an issue either for you if you lower the tower into the cockpit. In my video I explain my garage is technically less than 7'. I made extensions for the tower cables as well. See this thread https://jetboaters.net/threads/how-to-get-your-2016-ar192-or-ar195-in-a-garage-less-than-7.10369/
I want to very proudly say that the boat went in!!! No need to deflate or remove the tires or any special hitch, just collapsed the tower into the supports that it comes with and it rolled in thru the 7ft door. The angle helps a bit as I was coming up into the garage so the front of the boat was sitting lower. Where we struggled was with the width... I only had about 2 inches to spare on each side and it took a few back and forths until we cleared the wheels, that was the most difficult part! Right now it sits nicely in the garage, door closed and nice and dry! Thanks a lot for all the advice I couldnt be happier than to see it and know its thereI have to lower it to almost bottomed out on the jack to get it in with my tower folded in. Trailer wheels are on and no deflating or any of that.
