QCI Sean
Has anyone removed the catalytic converter from their AR230, SX230 or any 4 stroke post 2007 Yamaha? This question will only apply to those living in CA and NY, since those are the only states that required cats for these boats (I don't need the haters to chime in from AZ, so please save yourself the time to hate on CA).
I have a 2008 AR230HO and I was getting the error code for a blocked cat on my port motor. I ordered a new cat (a grand) and when I went to install it, the existing one was totally open and fine. I still ended up putting the new one in, since it was non-returnable, but I am concerned that I will run into the same issues again once on the water since the original one had no signs of blockage.
I have found articles about adding a D-plate and chip to older 2 stroke Yamahas when pulling out the cat, but nothing for my boat. If I have to, I may end up hollowing out my original cat, but am hoping not to have to do that if possible. At least I will have the other one if I screw something up though.
before changing out the cat, the boat would run fine unless I had it at WOT for 20 seconds or longer. If I had it wide open, the exhaust would overheat on my port motor and eventually blow the motor if it was to go unnoticed that the dummy light was blinking (don’t ask me how I know this)
Any help will be appreciated. Thanks!!!
