boudin
- Lake Livingston, Texas
Its definitely not a time issue, but bad luck.
Moisture in any cylinder when laid up will ruin the walls and when you start up it grinds down the rings..... then loss of compression happens......
Fog it heavy if being laid up
Agree on the fogging if the motor is going to laid up for a while.
The MR1 cylinders are Nikasil coated and should not rust. However, the steel piston rings will rust and stick causing low compression. You can get rust from the rings sticking to the cylinder walls, but the walls should not rust.
If I recall, the older FX140s were not Nikasil coated.
-Greg
