eslocum
- Winnipesaukee NH
Did a lot of research over this past winter for the right underwater lights and where to place it on my 2016 AR240. I ended up going with two Lumitec SeablazeX lights (Blue/Clear). Wanted a quality product that would last and produce the most lumens, without breaking the bank.
Was a little nerve-wracking drilling into the hull of my boat, but the results were awesome. The instructions call for drilling a 3/8" hole for the main wiring and smaller for the 3 supporting screws. I ended up drilling a 1/2" and filling it with epoxy to give an added layer to prevent de-lamination, and then drilling with the 3/8". Screwed it in and used black marine sealant to do the rest.
Be careful on placement as the muffler's outlet is on the opposite side. I did the wiring work using the access panel which is located between the clean-out plugs. Standard 12V Marine wiring, a fuse, and a couple marine switches later there were good to go. They are super bright and can be easily seen even at dusk.
Definitely a must-have upgrade if you plan on doing any late night boating. Ill follow up with some late night photos in the near future....
