VONCE
- Dayton, OH
I am going to attempt to put ballasts in the compartment under the swim platform. I still have to get it ready (puncture-proof), and this isn't on the top of my boat project list, but I figured I'd give it a shot as time permits. I decided to go with a reversible pump. Based on my research, it might not be the fastest, but it's self priming which is necessary. I want the bags to drain out of the side of the boat so I have indication when they are empty so I turn off the pump. I also want the vent to share a thru-hull with the drain (the less holes in the boat, the better). I understand this is going to require extra tubing and check valves and all that good stuff. I mocked up a drawing with my ideas. Can y'all look at it and tell me what's right and wrong? (lookin' at you @jcyamaharider!) I was going to use 3/4 inch hose but I haven't purchased it yet. I was informed 1 inch would be a better choice. Does it matter with a 300gph pump? I figured the pump would be pretty slow with low flow (which I'm fine with - I'm new to the wakeboard and wakesurf thing and I'm sure the pumps would work while I'm idling around which is 80% of my boating trips anyway...). Thoughts and opinions are appreciated.
