Batteries low voltage alert
webbug
Checked the connections and found one wire not connected to the negative ground. Will it be the problem affecting the charging of batteries?
I developed the same problem a few years and many mods in. My boat came with a short negative cable unattached. After some reading here I found that this was to tie the two batteries together , negative to negative. I haven’t seen a low voltage warning in the years since.
Looking at the pic, you need to attach that lead, I don’t recall the exact function but believe it’s a sensor that is needed for the system to determine what battery to charge and/or whether the system is charging or maintaining the batteries.
webbug
Stupid dealer, I will connect the cable and observe
