Tailwaters
- St Joseph MI
- FSH Sport
So I'm assuming the foam was exposed ? Meaning liner- void-foam? Or liner-void-liner-foam?
I tried to warn you...! LOL.That sounds right from what I could see down the rabbits hole. I think it's better left alone for now. I'd still like to get that water out of the battery compartment area though.
Good one!If you see pavement, you've gone to far
I also started a new thread to get a few more eyes on the issue.There's obviously some water trapped under that area and enough that it would provide enough pressure to push out of the holes. Try lowering the bow down as far as you can and see if you get any water through the floor drains in the changing room. Or place a floor jack under the trailer and try lifing up that side of the boat as high as you can to see if you can get the water to go to the center of the boat and drain out. This has been my concern and why I had ask if anyone had a diagram of the hull and stringers. It would appear that the hull liners are attached to the hull by means of some type of epoxy. Which means there could be liners glued in that have voids at the seam and allow water to enter but not exit.
Great minds think alike. I used my wet dry vac and vacuumed out a few ounces of water. It fills VERY slowly. Wait a few seconds and it fills with about a teaspoon of water. If it is a void it must be big enough to reach the screw holes. But again, why would salt water collect above the waterline?That's the side that has the drains. I wonder if they could be leaking enough to take on a little water and settle on that side. My last boat was foam filled and had low spots that water would collect in and never drain . Here's what you need to do. Take a wet dry vac and duct tape a straw to it and stick it down in the holes and see how much water you suck out. Could just be a small void with a low spot?
Not the wash down hose side. It's really an inaccessible spot. The drain hoses are visible there and not below deck as well. It's still full of water today. I just sent the dealer an email and I'm going in Tuesday for a replacement console insert (the glove compartment part that's black plastic).Do you ever use the washdown hose? It could be the rear floor drain a small leak. That would be in the same area. Did you try pulling the helm access panel to look over that way. May need a light and a mirror to stick down in there to get a good view.
