fireflymedic
- Bonifay, Florida
Why can't someone develop some kind of thick rubber inflatable ball to put in jet from the clean out port to block water flow instead of having to find the right hose to clamp? If you run on 1 engine. It does have a shaft in the way so you may have to have a split in it or have two half pieces to shove in it left and right or something.
@JetBoatPilot or some plastic rubber engenders it should be doable
Any way just a random thought came to me wile cleaning boat.
