dadofral
- 49426 Hudsonville, MI
- X
Last fall before putting the 212X away for winter a portion of the keelguard / shield came loose, I crawled underneath to remove what I could and found the area around the bottom of the V on the hull many fine scratches from beaching the boat....my thought process is to find a hull coating that is abrasion resistant to go over these areas after a fine sanding, etc. I don't want to get into repainting and new gel coat due to the cost for a boat that is in great shape but still 8 years old.....any recommendations on a good coating? It would only be on the effected areas and not seen unless the boat is on the trailer...want something that can be color matched as well if possible in a dark gray.
