Pointblank
- Houston, TX
- Limited S
Has anyone installed an overhead boat lift for their 242 or similar? We're finishing our boathouse build and trying to determine the best setup.
For the motor, we're looking at an 8500lb 1.5hp single pull which could be expanded to 12000lb with a double pulley if we ever needed it (unlikely). For the lift, the builder recommends straps instead of a lifting cradle. I've seen reports of straps compressing the hull over time. However, I'm equally concerned about the cradle getting tossed around by the semi-rough wave conditions and that it'd be trickier to dock if not inflict more damage.
Other than a GEM remote, does anyone have any other tips or advice they could share before we lock down the design?
Thanks!
Thanks!
