What size guide on posts are you using for your 190? The west marine near me only has 40 inch in stock and it looks like those are for jet skis. Do I need 48-60?
The PVC portion slides off the metal L brace so it doesn't matter what size you go with. The 40 worked great for me and you can easily build on to the PVC if needed.
A side question here, but how do you like the positioning of your mirror with the fixed tower arm? I have been debating whether I should get an articulating one to play it safe, but they are more expensive for something that already seems over priced. I just hate my windshield mount so I think I need one.
192's have metal rub bands so no, I've not experienced and scratching on the boat. There is some on the pvc from the screws securing the banding. I will probably get covers eventually.
Today I swung by Academy Sports and picked up as set of 60" C.E. Smith LED trailer guides for $99. Comes with galvanized frame and stainless hardware so no worries with rust. I may cut them down to about 50" if they look like they'll interfere with my garage since I have a lip on the slab floor which affects my overall garage opening. Gonna install them tonight after work! I'll get some covers for them eventually.
@haknslash Make sure you check it out when you have the trailer in the water. I have the CE Smith poles with the LED's on the top. If they are seated all the way down, they kind of latch in and don't float up when submerged. If the boat rubs by the little LED caps, it'll make a gnarly scar on the hull. It's better to be tall than short. Otherwise, I love having the LED's on the top. Both for driving and for backing the empty trailer down the ramp at the end of the day.
Also, I bought the pads and covers online from CE Smith. Beware, they are a b!tch to get on!
@Bill D I noticed there is nothing technically securing the guides to the metal frame. They just kind of slide into that metal "non-rotate" tab on the frame. Have you had any issues with the guides trying to move around while driving if you hit a hard bump or anything? I was thinking about drilling a small hole and adding a screw to lock the guide in, similar to what you do with the LED cap on top.
I'm going to keep them at 60", so I shouldn't have an issue with the LED cap hitting or anything.
No issues with them moving around while driving. On mine the little "non-rotate" tab kind of secures them down. They are surprisingly secure. I was thinking about drilling a hole to put a pin in to keep them up high enough to clear the rub rail, but as long as I remember to pull up on them a little before backing in, they float high enough.
