- X
Article from Boat US, submitted FYSA.
January 23, 2015
Dear BoatU.S. Member:
If you fill your boat up at Sheetz gas stations in North Carolina beware of E15 or gasoline containing 15 percent corn-ethanol. There is not a single marine engine warrantied to run on this higher blended fuel and any damage it does to your car may not be covered by the manufacturer warranty, according to AAA.
Sheetz Convenience Stores announced on January 21, 2015 that they will offer E15 fuel at 60 of their store locations in North Carolina beginning in early 2015. Because this fuel is often the cheapest at the pumps that offer multiple fuel choices, please take an extra moment to ensure you aren’t filling your boat with any fuel containing more than 10% ethanol. It is not only unsafe for you to use this fuel in your boat engine, but you are prohibited by law from using it in marine engines as well as other small engines such as lawn mowers, leaf blowers, snowmobiles and line trimmers.
BoatU.S. will continue to lobby Congress to reform the Renewable Fuel Standard (RFS) – a law which forces these higher blends and less compatible fuels into our markets. For more on the Renewable Fuel Standard go to www.BoatUS.com/gov.
Thanks for being a BoatU.S. member!
Nicole Palya Wood
BoatU.S. Government Affairs
A quick interwebs search yielded similar results:
http://www.snopes.com/politics/gasoline/e15.asp
http://www.bassmaster.com/news/e-15-disastrous-outboards#
@waterboy @96Pirate @Julian @DieselCamel @veedubtek to name a few
@txav8r for his wide range of knowledge
January 23, 2015
Nicole Palya Wood
