Boattest.com talks through 'exploded' version of Yamaha's propulsion
swatski
North Caldwell, NJ
buckbuck
Texas
I consider that a well done simple overview for those unfamiliar with jet boats. Good job boattest.com.
msavold
Columbia, MD
Bruce
Royal, AR
Scottintexas
Corinth, TX (DFW)
Added to the FAQ under 3 different tabs about pumps and impellers,
jameskeller76
Georgetown, TX
Nice PR piece paid for by Yamaha.
mattster
Carmel, IN
Limited
And why don't these boats have variable trim nozzles? the video didn't address that--seems like they'd benefit?
Beachbummer
Houston TX
Seadoo had it for some time on some jet skis. Turns out electric motors don't like getting wet, and there are some loses due to friction and redirection of water.
Trim tabs work for me, I don't need my bow higher, just lower.
mattster
Carmel, IN
Limited
Yes, I had a SeaDoo with vertical adjustment of the thrust--you could make that thing jump out of the water. I'm kinda surprised nobody has done a mod for that on the boats.
Cambo
Long Island
The e versions are using electric motors to control the gates the adjustable trim would probably be great for surfing. I was up surfing as soon as you get near the jet wash it can blow the board away. They probably cant do both adjustable trim and reverse it works on the jet ski do to the size
Beachbummer
Houston TX
It's all time and money, saw someone send pictures of their pump part replicas from their own Mill and it looked fenomenal not a month ago. I bet it could be done for 2-3k. But it's a good chunk of change.
Beachbummer
Houston TX
Maybe even rotate the current nozzle 90 degrees and use a rudder system for steering instead.
jjmparsons
Huntsville Al
JDFester
Loganville, GA
Link is not working at boattest.com; I believe this may be the same video on YouTube?
