Wrecked Rooster
- Ada, Oklahoma
Ended up buying the following and this will be phase 1:
NAPA battery with 75 AH and 460 CCA
Would adding 2 of these in parallel be a good idea?
122 AH each with 845 MCA
Would like to set it up to have the audio system run off the the 2 everstart batteries while the ignition is off. Leaving the stock NAPA battery alone to still power on the boat. *Bonus* - would be nice to be able to crank the boat over off the Everstarts if main battery fails for some reason.
Phase 2 will be adding the following:
- Four 6.5" speakers at 65W RMS to replace factory ones
- 4 channel amp with 75W per channel @ 4 ohms
- KMC4 headunit
- 9-11" tower speakers with 150-300W RMS
- 8-10" sub with 3-400W RMS
- *Maybe* 2 additional 6.5 or 8" speakers for the interior
- Amp to run the above
