Bow roller hardware
Ballshrinker
AR195
I have 2022 ar195 and purchased stoltz 3.5" center and 434 bell ends. Thinking about switching tomorrow at dock. Do I reuse same hardware or do I need to buy new hardware. I have company with me and don't want a cluster. Any help would be appreciated.
Farny
Spring TX
Centurion
Should be easy as pie. I switched mine out in the garage with the boat on the trailer. Pretty sure the old hardware will work. Stoltz didn’t send you a bolt washers and locknut?
Ballshrinker
AR195
I had a hard time figuring out what to get and bought them separately
Farny
Spring TX
Centurion
I think the existing will work. Good news is even if it doesn’t you’ll only waste about 5 min of your time finding out today. Just bring the correct size wrenches and your good to go.
MrBubbaGump
Swapped mine out when I parked the trailer at the ramp, just brought a ratchet with the correct socket and a breaker bar with a socket as well... Took about 2 min.
Ballshrinker
AR195
I took it off and tried to put the new ones on but the inside member was too short, like 1/4" gap on both sides. The bolt wasn't long enough but maightve been if the bracket was squeezed together.
Did yall have to squeeze bracket together or did I buy wrong center member?
MrBubbaGump
Did not have to squeeze together
Ballshrinker
AR195
I bought stoltz rp335, 3". Was that the right one?
MrBubbaGump
I have the 210 FSH and i got the Stoltz rp355 3.5 inch Here
Farny
Spring TX
Centurion
Rockit69
195S
I bought this one and it worked perfect, raised the trailer all the way up and it rolled off the roller about a 1/2" and was able to swap it out at home. I got a new bolt with the set and I think it pinched in a bit, as long as the brackets dont bind against the rollers you should be fine.
Cbullard3895
Apex, NC
212SE
mine came with new hardware.
