Bow Stop moving on Shorelander trailer
CLBeerbower
Castle Rock, Co
212X
Has anyone welded or put bolts through the bow stop to get it to stop moving? I have a new 2021 212XD and I stern straps are constantly loose due to the bow stop moving .25 of an inch during trailering. I can see the wear marks from where it moves. The two carriage bolts are right as I checked them. Curious what others have done. Thanks!
All you have to do is do a quick stop once to level ground and then sinch up the loose straps and you should be good. Either that or drive about 5 minutes down the road and stop, once you do either of those you should be good for the rest of the drive. (Boat Buckles are a must though, the factory straps sucks)
