- Royal, AR
- SX
I ran a water hose into the bilge to check my scupper valve install for leaks this afternoon.
I am glad to report that the scupper valve is well sealed.
But I found that the bronze drain plug is slowly leaking between the threads. I tightened it with a wrench before adding water to the bilge. I can not see it leaking but I can feel moisture on it. I am going to leave the water in there for a day or two and see how much leaks out. I have a plastic tub below to catch the water.
I know that my 2007 SX 230 was one of the models that had issues with the factory drain plug. I believe the bronze drain plug was installed as a fix to the issue with the factory model.
I do not like the bronze drain plug because it requires a wrench to install and remove.
I see my options as replacing the drain plug and mount with something new, perhaps the stainless steel part used on the current boats, replacing the bronze drain plug with another bronze drain plug using the same mount or using thread tape when I install the drain plug.
What do you guys recommend?
