- Corinth, TX (DFW)
have you ever had your impeller/shaft out before ??
No doubt that bumper is causing resistance but I wonder if you've never removed it before if it's not just "vacuum" sealed, we just had another member a few days ago who had to tie the pump off to the truck to get it out, maybe if you can get a ratchet strap on it to apply some constant pressure and tap it with a hammer ???
also wonder if it was the bumper, I wonder if you could stick a butane torch up there to melt it at the impeller to help remove it ????
