Catalyst housing for my Rotax 1503 size 250
Ricardobq
HO Impulse
The housing for my catalyst converter cracked (its a Rotax 1503 size 250 for my Scarab boat) and its leaking water. Please let me know if anyone have one for sale new or used, housing or full assembly.9ECBDB3E-8B75-4783-9DA5-9EF2957C4A25.jpeg2965E2A2-ECE3-4316-B6E6-3A8B51AF0D13.jpeg893CAFD8-0E3E-47D4-A81F-862437D9854D.jpeg
Just putting this out there...Could this be welded?
So regardless that it "might" be covered under warranty, you'll attempt to weld it.
I'd call your nearest dealer, or a few and see if it falls under the bulletin issue...
Even if my warranty is expired?
While dealer and Rotax replay I'll try to weld it. Any one have any idea about the material of this housing?
I was told by my dealer that it's a sort of soft recall, only recognized when it fails, and would be addressed/fixed at no charge to the original owner if and when it fails.
The two local dealers in south florida don’t even had quoted the parts, they say are waiting for Rotax. And Rotax dont help unless I have a part #, formal channel its a dead end. Fortunately the piece is aluminum and It was welded and reworked. Can any one help me to get the torque for the screws and the gasket part#?
im in south Florida as well and had mine Replaced under warranty. You can go to any Riva Yamaha or Even Broward motor sports now services Scarabs.
Was your std warranty expired?
Does anybody know if you can just obtain the part under the recall?
I am having the same trouble with finding mechanics.
No one will work on my boat to honor the recall on this catalytic.
I am forced to purchase the new O-rings resurface the mating surfaces if its even possible and cross my fingers.
What a joke.
I bought my boat brand new from the dealer and was never informed of this recall through proper channels.
My own dealer is not even a BRP certified and does not even have the BUDS SW from BRP.
The local Scarab dealer just simply said "we don't work on those."
Would be nice to just get a new Catalytic shipped for me to swap.
Does anybody know if you can simply bypass the catalytic with an exhaust component from a non catalytic model?
I say you call BRP inform them of the servicer situation, and see of they can send you in a direction to an authorized servicer, or you may have to call Glastron to do the same.
At the end I never got any type of support from the dealer, scarab or BRP. The housing was repaired and we had to use Hitemp silicone because they even did not reply about the orings. So far is working great.
Here are some tips, since I got a failiure in one O2 sensor I had to get it from the dealer part# 0461576 and guess what the f.. sensor comes with the housing orings and no one can tell you that...
If the dealers do not have it in stock you can order it in amazon (w/o oring kit) with under Bosch 18127 Oxygen Sensor or part# 0258006956
A little research on the part number from the catalog listed above, does describe sensor, and O ring assy.
This is criminal.
Glastron ignored me, BRP closed my case without giving any answers, and NO dealer withing 100 miles will touch my boat.
Its pathetic.
Thank you for posting your resolution.
Looks like I will be forced to start wrenching again.
Sounds like the start of a class action to me.
Just as a referecence I paid $88 bucks for the same item at the dealer, they had it in stock. And $79 for the other part# (sensor without the orings)@ Amazon. Both the same sensor.
There must be an underlying issue or circumstance surrounding the lack of support from the dealers. Even though a dealer may be a Rotax authorized service center, IE: Chaparral, Scarab, or Glastron, it's my understanding that regardless of the Rotax propulsion there are specific and multiple licensure requirements for each boat brand. To sell the brand, to service the electronics, and possibly sell the parts. I am unsure if there is a general BUDS license allowing access to all boat manufacture platforms. From what I understand, there may be a BUDS license for each manufacture brand regardless that it's still Rotax powered.
On the other hand in the past I have asked my Scarab dealer, if I ever need service for this same issue would they be willing to make the part replacement, and they have said yes.
