jgiovino
- Melbourne FLorida
- Glastron
- GTS
... if I ever need service for this same issue ...
I would recommend being proactive and not to wait until it fails.
I hear from other threads on this forum that this is mostly for te grey cats and not the black ones.
I just took mine out and its a mess.
Since the O-ring seals failed, water got between the S.S bolt and aluminum threads.
I have to torch each and every bolt several times to get the bolt to back out of the aluminum flange without destroying the the housing.
Whoever designed this housing failed by not through-bolting it.
Once the seal fails, and it will, gravity brings the water straight down to the exhaust manifold and into the heads.
There is no riser to prevent water from backing into the manifold.
Check out the cost on the parts for repair:
EXHAUST SYSTEM - SINGLE MODELS, WITH CATALYST - AA Powertrain 250 440000AAA | Crowley Marine
View parts diagrams and shop online for EXHAUST SYSTEM - SINGLE MODELS, WITH CATALYST parts, AA Powertrain 250 440000AAA. Offering discount prices on OEM parts for over 50 years. FAST $4.95 shipping available.
