  • JetBoaters.Net 2nd Annual SeaDoo Switch Group Buy Sponsored By JetBoatPilot Is Live Now. Save 25% Off Select SeaDoo Switch Gear through October 31st.
    Click Here to go to the Jetboatpilot Seadoo Group buy
    You can delete this notice with the "X" in the upper right>>>
Changing a wear ring in a Glastron 187 gts
Fitter0104
Glastron
GTS
Has anyone ever changed the wear ring in a Glastron 187 gts yet. I was wondering if it was complicated. I read if you lose a bit of power it can be the wear ring. My boat is a 2014
It's not that hard, you can find video's on youtube for the replacement. One tip, put the assembly in the freezer, and it makes getting the ring out easier. You can get the ring from pwcmuscle.com
When you changed the ring? What size was it?
