J-RAD
- Orem Utah
Possibly, although I think the Rotax engines being supercharged may make the altitude change less noticeable, but I can't verify?I would want a demo in the other boat at altitude to get a apples to apples comparison, aren't they going to suffer from the altitude also?
I'm at 4,500' El and with the ribbon delete and a loaded boat I top out in the upper 40's. It's the top end the suffers, performance is great in every other aspect. Still a higher top speed than most any wake boat. Even with less power the acceleration difference between the two boats is still marginal in comparison due to the weight difference between them.
I'm still holding out for the day Yamaha puts twin SVHO's in the 24ft boats, it only makes sense if they change the pump volume to match what they've done in the supercharged 195's. There's just not enough volume to make it efficient in its current design, I think all it would do is burn more fuel... maybe I'd see a bigger difference being at elevation?
