Welcome to Jetboaters.net!
I have a 2018 Chaparral 243 Vortex VRX and keep getting an active engine fault code of C2102 (EREV) with a message coming up of eReverse Module Disabled. Anyone know what could be the problem?
I would check and see if there's anything interfering with the movements of the buckets. This can be done in the e-reverse screen; press the button to manually move the buckets with the throttle lever (forward and then back).
If nothing happens, make sure the breaker is not tripped. If it is, press the red lever back up into the breaker.
