Cleaning clean out plugs
bronze_10
Raleigh / Wake Forest Area..
Soni have been searching the threads trying to find out what to soak my clean out plugs in... I gave read several threads and see where people take about doingnit but injavent been able to find what solution is used to soak them.. can someone help me with that..
They are not sticking.. when they are wet they go in easy.. when they are dry they are a bear to get in..
Rebuild them and they will almost fall into place. It is well worth the $80 and 20 minutes.
I put some gasket lube (available at any pool store) on the rubber gaskets on mine periodically. It is a silicone based gel and keeps them nice and fresh. Others have suggested a silicone spray (like WD-40), but the gasket stuff works perfectly for me with less mess.
