CO risk on swim platform
In California it is illegal to ride on the swim platform while underway. The CO stickers are the only one's I've left on the boat, not that it means much because I always shut the engines off if anyone is in the water.
The same law exists in Minnesota. I also think it is too easy for someone to fall off the back with the acceleration of these boats. I shut off the engines with people in the water too, except when on the other end of 50-75 feet of rope! :winkingthumbsup"
If you're curious, CO is recognized as a potential problem in many smaller general aviation aircraft (Cessna 152, 172, etc.) and there's a bunch of cheap detectors that you stick to the panel for protection such as this: http://www.sportys.com/pilotshop/carbon-monoxide-detector.html. It 'resets' when exposed to fresh air (so you'd have to keep an eye on it when checking for effects) and is good for 90 days.
For $4.95 it would be a fairly interesting test...
We did a test last summer with a portable co monitor held by a person surfing in the usual spot (deck start) . It showed from 0 to 5ppm. Our concern was we body surf back there. I think big issue is guys hang off the platform on wake boats with no life jacket, face in the exhaust, then surprise. Cam
CO exposures come in two flavors, acute and chronic. An acute exposure is a high level exposure and can kill you quick...the chronic exposure is the one we see more often...CO builds in the bloodstream over time from a continuous low level exposure...so I can see the possibility of disaster from sitting back there over a long afternoon under power...
We don't ride on the stern but I sat back there once (PFD and hold on tight) at WOT and what a ride!!!!
