McMark
- Monongahela, PA
Sending some engine mojo your way.
what does the exhaust manifold and collector look like? i agree with @bronze_10 and @itsdgm that this may have started prior to limping home. disassemble the entire exhaust and look for corrosive penetration of the water jackets - though i hoped it would never happen, i've been waiting to see someone with a catastrophic failure due to this as i found one of my old manifolds were nearing break down.
someone please correct me if i'm wrong here: the engine could potentially run fine with a jacket leak. but if you cut the engines while underway, thus stopping the exhaust pressure, the leaking exhaust jackets could back flow, or suck, into the pistons due to the forward momentum pushing more water in? i would think this theory would be hard pressed to allow that much water in, though. but maybe it caused the non start and then the clamp wasn't tight enough, allowing more water to fill it up?
@ToddW850 haha, trust me, I'm venturing into territory here I'm no expert in either. I was actually unaware of the exhaust differences between the 210 and 230, but the principal still applies. just throwing ideas out there for you.
I believe all those crystals in the exhaust ports are salt deposits. I had those in at least one of my eight between both engines. coincidently, that engine also ingested a fine water spray into the airbox from a cooling line pinhole. someone help me here: those crystals are not "normal," right? can we assume that is from: salt water leaking from the exhaust jackets; being expelled after being ingested through the air intake; the head leaking; or something else not right?
relatively speaking, those of us pooling our knowledge here and predominantly using these boats in salt are a small group, so there's not much to go on as these earlier models start developing long term issues. I'm sure if we were to scour the PWC forums, we could turn up some clues. example: after developing an overheat issue, I've found some PWCs with the same engines developing large sand/salt deposits in the "front" piston jacket exactly where I'm reading high temps on mine.
